• 19.11.2026, 07:20
gezzas525
Aquaero freezes Apple USB keyboard
Donnerstag, 26. Januar 2006, 01:53
System is an ASUS A8N32, whenever the aquaero is connected to the internal USB headers my Apple keyboard freezes at the Windows XP logon screen with the CAPSLOCK light on. This also happens at the XP install after after loading the raid drivers, running at default BIOS setting on the motherboard.
Top_Nurse
Re: Aquaero freezes Apple USB keyboard
Donnerstag, 26. Januar 2006, 05:01
Just curious as to why you would use an Apple keyboard on a PC? Does it do the same thing with a PC USB keyboard?
Added: What BIOS version are you using?
gezzas525
Donnerstag, 26. Januar 2006, 14:03
I like the Apple keyboard and its been in use through several PC's without issue, I'll try another keyboard allthough the aquaero wasnt freezing on my Abit KR7 and IC7 motherboards.
Running 1009 BIOS.
SquirrelM
Samstag, 4. Februar 2006, 23:05
I have the ASUS P5N32, and I'm suffering the same problem with a MS Bluetooth Keyboard & Mouse. It must either be a BIOS or driver problem. Unfortunetly I've had to send my Aquaero back as the screen has died, so I cant try the new drivers Nvidia released the other day. I'm running x64 windows, I don't know whether this is related to the problem, but as it works fine once the device is unpluged and plugged back in i suspect its not.
Euphoria
Samstag, 6. Mai 2006, 02:56
I've been having the same problem, but after hours of playing around I've finally found the solution (really simple too)!
Basically, on my motherboard (A8N32-SLI Deluxe) there are 2 sets of USB header pins. I tried the other one out, which did envolve moving the Aquaero, but it not boots and my Apple keyboard works along with everything else!
:D
