• 10.11.2026, 16:38
Isaksson
Sensor Offset
Sonntag, 28. Mai 2006, 22:19
Hello.
When i started my computer all the settings where changed in the aquaero,
I think that flowsensor should be 519 in calibration, but i hope you could help me what i should type in Sensor Offset in k and sensor factor for the temp sensors, becourse i have no ide what i should use there.
And i also need the calibration value in impulse/rev for the fans.
I could also use the default settings for the VFD display.
Thanks
Re: Sensor Offset
Montag, 29. Mai 2006, 01:25
Default values are:
Sensor Offset -> 0,0
Sensor Factor -> 0
Impuleses/Liter -> 509
Impulses/Rev -> 2
For the display: set it like you want, there is no real standard. Contrast isn't working on VFD and brithtness is pretty self-explanatory ;)
Isaksson
Re: Sensor Offset
Montag, 29. Mai 2006, 18:07
Thanks for the info Shoggy.
do you have any ide why it auto changed the settings?
