• 22.11.2026, 22:08
X-t-r-e-m-e
Water vaporizes?
Dienstag, 30. Mai 2006, 17:23
Problem is as follows:
Setup:
Aquastream
Aquatube
Cuplex XT for Athlon X2 3800+
Twinplex pro for 7800GT 512MB (Gainward)
Twinplex pro for chipset
Black Ice Extreme 120mm rad
Tubing PUR black plug & cool
All temps are around 50 to 60degrees, for all cores (proc, gpu, and chipset). I checked several times for leakage and cant find any. I double checked. Been running this setup for over a month, still all works well, so again, no leakage.
But where the hell does the water stay :S I mounted the aquatube in front, and the waterlevel goes from full to half in two weeks of intensive gaming. Surely this cant be the meaning.
Anyone got some tips?
edboswell
Re: Water vaporizes?
Mittwoch, 7. Juni 2006, 04:47
hm probably you just havn't messured it properly in the first place... If it was leaking it would probably go down quicker....Last of all you might have some air still in it somewhere?
vils
Sonntag, 11. Juni 2006, 00:17
I think that the air always present in tap water have escaped the water and you see this as if the water level is lower.
It's still the same amount of water but undilluted.
Its hard to explain in english :P
/Vils
All work and no play makes Jack a dull boy.
vils
Sonntag, 11. Juni 2006, 00:20
I tried to write escaped but its transformed to eskapped?
/Vils
vils
Sonntag, 11. Juni 2006, 00:22
e-s-c-a-p-e-d
/Vils
