• 05.11.2026, 09:12
Isaksson
problem with two aqaustreams
Sonntag, 21. Mai 2006, 17:29
Hello.
I use two pumps (aquastreams) and i have them connected to my aquaero.
When i open up aquasuite then the status on the pump change all the time from
status: Pump OK
status: Deaeration Mode
Not Connected
even that the pumps are working.
i have seen it once that he changed the pump to
deaeration but only for like say 20 sek then he changed it back.
but i dont like the ide that i leave my computer on and then maybe he change it to deaeration mode.
I have set the adress so that should not be the problem.
do i have to use the first on on the cable to the adress 1?
and i dont have the power connected to the aquastreams.
Firmware is 1.31 on both.
do anyone have any ide what i should test?
Thanks
Edit
here is some pictures so that you can see what i mean.
http://213.113.110.198/aquacomputer/aquastream1.jpg
http://213.113.110.198/aquacomputer/aquastream2.jpg
http://213.113.110.198/aquacomputer/aquastream3.jpg
/Edit
Isaksson
Re: problem with two aqaustreams
Montag, 22. Mai 2006, 02:02
I have now tested to disconnect the tubemeter and now it works.
is there a fix for this?
i have read that if you have problem with the tubemeter and aquastream then you should connect power to both of them, but i dont think that it will solve my problem becourse the power is not my problem becourse the pump workes.
maybe anyone have any ide?
Montag, 22. Mai 2006, 02:10
The tubemeter is responsible for your problems. The only solution is to connect the power to the pump.
I have no idea if you have to plug it in for both pumps or only one of them.
Isaksson
Montag, 22. Mai 2006, 14:11
Does it help if i connect the tubemeter throu USB instead?
Montag, 22. Mai 2006, 23:35
Please connect both pumps with power. This will solve the problem.
Isaksson
Donnerstag, 25. Mai 2006, 00:04
I have done that now and it worked great.
Thanks for the help.
I will post some image of my computer in next week i guess.
Iam waiting on a couple of connectors from AC i think they will arrive next week.
pharao
Donnerstag, 25. Mai 2006, 00:08
do! in this forum, everybody is crazy about pictures :)
Isaksson
Donnerstag, 25. Mai 2006, 00:29
-edit-
i missread your post
so i dont know what i should type here instead.
Well, AquaComputer for All.
-/edit-
Isaksson
New question.
Donnerstag, 25. Mai 2006, 15:10
I have a new question.
I have one new pump and one old pump(that i have used for maybe 1 year or so.)
The old one is aquastream 1 and the new is aquastream 2
Why is there so mush difference in Power and consumption?
FreezedComputer
Sonntag, 11. Juni 2006, 03:14
mh...misunderstood....i dont know :-X
Montag, 12. Juni 2006, 23:23
Different firmware-> different phase control.
