• 02.10.2026, 07:24
mattjbak
I have a bit of a problem. Please reply quickly!
Sonntag, 25. Juni 2006, 04:28
I just bought an entire WC setup as follows:
Swiftech MCR-220 "Quiet Power" Series Radiator - Black
AquaXtreme MP-05 SP Limited Edition Universal CPU block
Swiftech MCW60 GPU block
MCP655 pump (Laing branded)
7/16" ID (5/8" OD) Masterkleer tubing
Aquacomputer Aquatube Reservoir and Faceplate (Black)
YATE LOON 120mm Case Fan - D12SL-12 (Quan: 2)
Scythe Anti-Vibration HDD Stabilizer 2 for 3.5" HDD (Quan: 2)
Petra'sTech "Gel-Stuff" Vibration Absorption Block
I just heard from someone on hardforum that the aquatube can't be made to work with the setup I have ordered. Is there any way to make it work? Thanks!
Matt
Sonntag, 25. Juni 2006, 04:54
Hi and welcome to the forum :)
I guess this person means possible problems with the connectors. Normally AC is using plug n cool connetors for tubes with an ID of 6mm and an OD of 8mm.
AC also offers screwed connectors with 8/10mm.
I don't know what 7/16" ID 5/8" OD is in milimeter but I'm pretty sure it will not fit the standard connectors. Maybe you will have to use an adapter or special connectors.
I have seen so many aquatubes in typical american big-bore setups. It should be no real problem to use it - you only need the right connection stuff (which I don't know).
mattjbak
Re: I have a bit of a problem. Please reply quickl
Sonntag, 25. Juni 2006, 04:57
thank you for your reply, now to find someone who does know the right connection stuff :D
Infiltraitor
Sonntag, 25. Juni 2006, 13:26
7/16" = 11.113mm
5/8" = 15.875mm
I guess you won't be using pushfits on that ;)
I'd say your choices are;
1. Rebore a pair of the Aquatube ports (probably one in the base and one in the side) to suit a larger fitting - 1/4" rather than 1/8" if possible. You'll be compromising the anodised finish of the Aquatube by doing this, so will have to think of other ways to protect against galvanic corrosion - carefully applying sealant around the fitting on the inside perhaps?
2. Use manifolds/splitters to split your loop into three and use all three ports in the side for in, and all three on the base for out. This can look a bit messy, but is the most practical solution that keeps the res in your loop.
3. Use the Aquatube as an air-trap only, without putting your loop through it. You'll need to put a T-piece in your loop - preferably before the pump, and just run a single line up to the Aquatube.
Whatever you decide, good luck :)
