• 23.11.2026, 00:59
tabxtra
radiator/fan Shroud ?
Mittwoch, 9. August 2006, 06:55
Does enybody use a shroud between the radiator an the fan ?
i have mountet my ac 240 radiator with the fans connected directly with the radiator.
(airflow)
(inside) | radiator-Fans| ------> (outside)
Is this wrong. ore should i use a shroud to get som space between the radiator and the fans ?
with a room temp of 25 and overclocking my pc 20%, my walter temperature is 30 *C at load
pharao
Re: radiator/fan Shroud ?
Mittwoch, 9. August 2006, 10:23
30°C watertemp is fine when you have 25° room temperature (and how ist Walter connected to your PC? ;D).
what radiator-type do you have?
an EVO, XT or pro?
the evo already has a built-in air shroud.
tabxtra
Mittwoch, 9. August 2006, 10:38
an EVO, XT or pro?
:) that's between Walter and me :)
I have 1 airplex evo 240 and 1 airplex evo 120
Thanks. that's a relief to know.
