• 29.11.2026, 02:27
SNIFFER
Temps
Montag, 21. August 2006, 15:20
My system temps hardly seem to change much even when working hard on 3D gaming. The water temps seems to be about 5-6 deg warmer than room temp.
I have temp sensors in the Aquatube and just going into Rad usually have a diff of 2 deg between them. My system has about 1 liter of water in it.
I have one temp sensor from the aquaero stuck on the side of the CPU block which hardly seems to vary.
Just concerned something is not right, or perhaps my placement of temp sensors needs changing.
Any advice here?
Surely, it should be getting hotter with gaming and aquaero has something to control.
SNIFFY
JaR
Re: Temps
Montag, 21. August 2006, 16:44
What hardware do you have? Doesn't sound like something to worry about to me.
badger badger badger ...
Nitrix
Re: Temps
Montag, 21. August 2006, 16:49
the idea of water cooling is to not only give youa better cooling solution but to also keep a constant tempreture level so it sounds fine to me!
