• 18.11.2026, 00:38
Oxize
New watercooling setup
Freitag, 1. September 2006, 03:01
Today i searched through the shop a little bit for all parts that i need for my new computer-system. For now i only want to cool my CPU. I can always buy an chipset/gpu block later.
System:
  • Lian Li V1200 Case
  • AMD FX-62
  • Asus M2N32-Sli Deluxe
  • Corsair XMS2 PC6400 2GB
  • Sapphire Radeon X1900XT
  • 7 HDD's @ 2TB
  • Enermax Noisetaker 600watt PSU
WC Items i gathered in the shop which i wanna use
1 x  cuplex XT mounting A64 Socket AM2/754/939/940 without fittings
8 x  Connector plug&cool straight G 1/8  (2 for Cuplex XT ,1 for Aquastream, 2 for Aqautube, 1 for Aquajet, 1 for Temperature sensor)
1 x  Spar-Bundle airplex PRO 360 ohne Anschlüsse + 3x airstream 120 mm
2 x  Connector plug&cool straight G 1/4 (2 for Airplex Pro)
1 x  Mounting plate stainless steel for airplex XT / PRO / evo 360
1 x  aquastream 12V-pump Rev. 3.5
1 x  Connector set for 1046 und aquastream without fittings (only adapters)
2 x  Connector plug&cool elbow G 1/8 (1 for Aqaustream)
1 x  Decoupling set for pump installations
1 x  aquastream connection cable (> Rev. 1.5) 70cm
1 x  aquatube Rev. 1.1 without fittings, blue
1 x  aquajet rinsing device for aquatube Rev. >1.1
2 x  Illumination-insert G1/8“ incl. gasket
1 x  Mounting plate stainless steel for aquatube
2 x  Tubing PUR natur, UV-aktiv, plug&cool
1 x  ClearBlue water additive 50 ml UV-active
1 x  ACfluid water additive 50 ml
1 x  aquaero 4.00 USB Fan-Controller, white/BLUE
1 x  Multi-Color Illumination module BLUE/RED
1 x  aquaero flow sensor without fittings
1 x  Set (2 pcs) connector G 1/4, plug&cool straight (2 for Flowsensor)
1 x  Connection cable for flow sensor (for aquaero)
1 x  aquaero plug&cool temperaturesensor (For in AquaTube)
1 x Plug 2pole for Relay output (for aquaero)
Extra:
1x Ball valve plug&cool
4x Elbow-Connector plug&cool metal
Some question before i gonna order:
* Aquastream needs 1/4 fitting or 1/8 fitting?
* What fitting for Aquajet?
* What fitting for Aquaero temperaturesensor (sensor placed in Aqautube)
* Why uses Airplex Pro 360 1/4 fittings and all other stuff 1/8? Do i need connection adapter for this?
* The standard PUR 3/8 Tube fits on 1/4 and 1/8 fittings?
Can someone check if i got everthing (power cables, connection cables,screws, fittings, etc)?
Thanks in advance,
Oxize
Ich bin ein Tukker :)
Oxize
Re: New watercooling setup
Samstag, 2. September 2006, 18:19
* Aquastream needs 1/4 fitting or 1/8 fitting?.
Someone?
Samstag, 2. September 2006, 18:53
Aquastreams need the adapter set and 2x G1/8 connectors.
Aquajets uses a G1/8 connector.
The inline sensor is designed to fit in a PnC connector. Just use a straight G1/8 PnC connector.
All products excepting the radiators and the flow meter are using G1/8. You don't need an adapter because the PnC connector is always the same.
PnC uses 8/6mm tubing.
For your list: I highly recommend that you use the active blue tubing instead of the clear blue additive. The uv active tube is MUCH better 8)
You are missing ac fluid! Note that clear blue is only for color, it has no anti corrosion abilities.
I can't see two connectors for your aquatube. Don't forget them ;)
You should also get the relais connector for the aquaero. It will enable you to shutdown your PC or switching other stuff on and off.
Oxize
Samstag, 2. September 2006, 19:38
Hmm which adapter set?
Can you still see the water through the tubes? Normally when you have UV Active tubes, the tubes are not transparant anymore because of the chemical ingredients in the tubes material. Nevermind, changed it  ;D
Ah good that you mentioned that. I already though i miss something :D
There already on my list -> 5 x  Connector plug&cool straight G 1/8  (2 for Cuplex XT ,1 for Aquastream, 2 for Aqautube)
I think you mean this one?
"Stecker 2pol. für Relaisausgang (für aquaero)". This connector can be putted on 12v cable from the PSU or from the molex?
Samstag, 2. September 2006, 20:07
I meant this adapter set.
The active blue tubing is a bit milky like the normal tube. No real difference here.
I use active blue in my PC and like it much more than the uv additive:
- at day without uv light
- at day with uv light
- in the dark with uv light
The relais connector is the right one. Simple and easy way to us it for emergency shutdown of you system:
Connect the aquaero parallel to the power-switch of your mainboard.
Oxize
Samstag, 2. September 2006, 20:23
@Adapter-set: Changed it.
@Active Blue Tubes: Jeah looks nicer. Changed it also.
@Relais: If you connect the Aqauero through an Molex, its act the same as the relais. So why this relais if the molex does the same?
Example: I push powerbutton. Power goes to molex, Aqauero starts up. Push powerbutton again. System/Aqauero off.
Or does this relais just act like an On and Off button? So when its get power it dont get on yet, but using this relais you can turn it on and off?
Samstag, 2. September 2006, 20:38
The relais will enable your aquaero to shutdown your system. Therefor it needs a connection to the powerbutton or the power_on wire (green) of your PSU.
Well, have you ever tried to shutdown your PC via a molex connector? Maybe David Copperfield can do that, but you won't ;D
Oxize
Samstag, 2. September 2006, 20:45
Haha okay, i understand it. Order Time!!!!  ;D
EDIT: Payment is underway!!! Total: 504.13EUR ;D ::) :o
