• 11.10.2026, 20:39
Oxize
Oxize Lian Li V1200 Waku/WC
Montag, 18. September 2006, 21:33
This weekend i got all parts from Aqaucomputer. Time to set things up.
Taping the case. We dont need scratches ;)
Marking off the cutting holes
Sawing ;D
Nice holes ;). Removing tape.
Radiator with Aqautube
Fully loaded system with AC ;D
AqauEaro and Aqaustream controllers + simple revoltec fan controller.
AqauEaro and Aqaustream controllers + simple revoltec fan controller in dark :)
Side-view
Side-view closeup
Watersplash in Aqautube ;D. Flow rate is about 63,50l/h.
Aqautube with Illumination leds. Dunno how to set only 1 led? Anyone know how to do this?
Some question to AC-Team.
The cuplex XT was delivered with 4 long screws and 2 special shorter screws like the picture below. Also there were 4 big springs and 2 shorten springs.
So far i know the 2 special shorter screws are for the stablisation plate behind the mainboard. You can just screw then into it. But you need also 4 of them to get the Cuplex XT AM2 perfectly fitted on the CPU Core.
I putted so long 1 screw upperleft and the other down right. It cools enough for at 39C idle, but when i give pressure on the empty holes my temperature getting lower.
So how can i get 2 more screws and 2 short springs(most left side of the picture) like shown on the picture below. I dont wanna use the 4 longs screws, because this dont give enough stabilsation on my mainboard and i want to keep the stabilization shield behind the mainboard. I think its better to include in the future 4 long , 4 of that special screws, 4 short springs, and 4 long springs, because every AM2 board got this standard.
Ich bin ein Tukker :)
Oxize
Re: Oxize Lian Li V1200 Waku/WC
Mittwoch, 20. September 2006, 11:02
I sended an email about the screws to Support. Btw, can i get also Artic Silver 5 from the shop?
Jogibaer_Nr1
Donnerstag, 21. September 2006, 01:15
Nice setup. Do you use the vario leds for the aquaero? You have to change the settings, dunno exactly how to set....otherwise ask sebastian from the Aqua-Computer Team or write an email...;)
anyway, nice case :) looks great for the little space in the case, but I see the Northbridge and the graphic card is non water-cooled >:( ;D
Oxize
Donnerstag, 21. September 2006, 23:07
This was already alot of money. I think in spring 2007 i buy some more blocks.
Still didnt recieved anything about those screws :(
