• 12.11.2026, 17:31
SeanBC
New WC Setup, need help
Montag, 18. September 2006, 01:37
This might be my first WC Setup... These are my specs and parts im interested in...
Specs::
AMD 3700+ San Diego S939
DFI LanParty UT NF4
OCZ El Platnium REV.2 2x512MB RAM
Coolermaster Extreme Power Duo 600W
EVGA 7800GT CO SE
1x WD 80GB IDE HD
Small RAIDMAX SCORPIO MidTower Case
WC Parts?*
CHIPSET:twinplex pro SLI Typ 1
VGA:twinplex pro for FX6800/7800 and X1800/X1900
CPU: cuplex XT mounting A64 Socket AM2/754/939/940
or cuplex EVO Rev. 1.1 mounting A64 Sockets
(Which one is better in performance?)
PUMP: aquastream 12V-pump Rev. 3.5 ?
RES: aquatube Rev. 1.1 (black) + aquabay AT
RAD(s): 2-3x airplex XT 120mm + grills*
Additive: BlueMotion water additive 50 ml UV-active ?*
Help with:
Connections, Tubing, Etc.
Would 3x 120mm radiators be good enough for this loop?
Is the BlueMotion additive non-conductive?
Which is better cuplex xt or cuplex EVO for s939?
does the twinplex pro sli typ 1 (chipset) work on my mobo?
Is the aquastream pump the best in the pump store?
THANKS!
SeanBC
Re: New WC Setup, need help
Montag, 18. September 2006, 01:39
Opps, ill also get aquaero 4
Nitrix
Montag, 18. September 2006, 01:57
hey,
Tubing and connectors depend on how your planning your loop so we would need more detail like case etc.
3 x XT120's would be fine but why not get a XT 360?
Cuplex XT is the best
The twinplex pro sli is for dfi board so you will be fine
The Aquastream is the best one :)
and as fair as i know bluemotion is non conductive but im sure shoggy or one of the AC guys will confirm that for me.
SeanBC
Montag, 18. September 2006, 02:57
no room for 1x 360
thanks.
pharao
Montag, 18. September 2006, 10:48
couplex XT is better, but it will only be a few degrees, so if you like the looks of the Cuplex pro better, just buy it
I'd recommend using PUR-tubing and plug'n'cool connectors. the tubes are quite stiff and won't fold (kink? crease? i don't know...) that easy. and they are really easy to install.
yes.
no you'll still need ACFluid. if you want blue tubes, you should go for the "PUR active blue" tube, it's white but glows blue much stronger than any water additive.
but you definitively need ACFluid.
if you plan having an aquaero and don't care about the costs: definitely yes
and: I don't see any Fans on your List. you definitely need some Fans.
there is a special offer at the moment where you get the XT-radiators with matching fans a little cheaper ("Bundle airplex XT 120 ohne Anschlüsse + airstream 120 mm" it is called.)
A_L
Montag, 18. September 2006, 15:32
Really suggest to get Aquaero, for you can monitor / control temperature, fans & aquastram pump control.
The setting is so powerful. I'd been using for a little while, but still study for the complete functions which it have.
;D
SeanBC
Montag, 2. Oktober 2006, 00:00
My case is the Raidmax Scorpio W868 Black. The Mid-Tower one, idk if theres room on top for 1x360...
SeanBC
Montag, 2. Oktober 2006, 04:59
can someone give me an estimated price in usd or cdn dollers for all of this???
A_L
Montag, 2. Oktober 2006, 09:03
HERE you should be able to get all the listed price of EU$ into US$ or CAN$.
;D
