• 07.10.2026, 08:21
d3daim
AC Flow Meter..flow rates?
Montag, 15. Januar 2007, 20:25
I have the AC Flow Meter and I will be using 1/2" barbs with G1/4 BSPP threading. I just took a look inside the opening of the flow meter to see that it narrows DRASTICALLY.
Wouldn't this have a terrible impact on my flow rate when included in my loop?
-d3d
Nitrix
Re: AC Flow Meter..flow rates?
Montag, 15. Januar 2007, 20:33
Probably if you are using a high flow 1/2" system as the flowmeter was designed to be used on a system that does not need "high flow" in order to work.
d3daim
Montag, 15. Januar 2007, 21:11
right..so the sensor
http://www.sharkacomputers.com/aqcoflcoseca.html
would probably be a bad to include in my loop. Damn.
edboswell
Montag, 15. Januar 2007, 23:17
well not necessarily... if you have the time.. i would check the temps of when you have the sensor.. and when you don't have the sensor... if they are a big difference then scrap the sensor.. but in my honest opinion.. I don't think the flow makes that much of a difference (especially if you have aqua computer blocks).
Ed
d3daim
Montag, 15. Januar 2007, 23:35
Alright, I'll keep that in mind. Thanks.
Infiltraitor
Dienstag, 16. Januar 2007, 00:32
What blocks are you planning to use?
d3daim
Dienstag, 16. Januar 2007, 01:36
I'm using a DangerDen Maze4 gpu block and a Swiftech Apogee cpu block.
Infiltraitor
Dienstag, 16. Januar 2007, 21:14
I'd look for another flowmeter then - the AC one isn't suited to your loop.
d3daim
Mittwoch, 17. Januar 2007, 01:59
Great, I appreciate it.
I just figured the AC flowmeter would be my only choice because I need the specialized output designed for an Aquaero.
d3daim
Sonntag, 28. Januar 2007, 11:05
You find any alternatives? Should I try to enlarge the flow meter hole?
I'm familiar with drill/tapping, I did it for the aquatube for 1/2" fittings..
