• 30.09.2026, 06:26
Oxize
Airstream
Montag, 29. Januar 2007, 20:09
Well after 6 months, my airstream fans (120mm) are hitting my airplex 360 Radiator with their blades. My fans are upside down. Air blows from under to above. So i think the motor of the fans is s getting wearing off. Its only for now 1 fan, but hearing a noise from blades that hit metal isnt realy funny, so i disabled this fan.
AC know with this problem? Is there a easy fix or do i need to buy a new airstream/papst fan?
Ich bin ein Tukker :)
Re: Airstream
Montag, 29. Januar 2007, 23:05
Try to adjust the screws of the fan. Normaly this will solve such problems.
Oxize
Re: Airstream
Dienstag, 30. Januar 2007, 19:05
Nope already tried that. It still hitting the radiator.
Infiltraitor
Re: Airstream
Mittwoch, 31. Januar 2007, 02:28
Sounds like either the circlip that secures the rotor/blades on the shaft has given way, or there's something stuck between the rad and fan.
I'd get a Papst or NMB-Mat (Panaflo) fan to replace it with.
