• 01.12.2026, 00:06
cypriobrit
Clarification needed on poweradjustUSB and Aquaero
Sonntag, 13. Mai 2007, 13:36
Hey guys. First post! :)
Need some clarification on whether or not the USBPoweradjust can regulate my Laing DDC pumps automatically if integrated into Aquasquite via an Aquaero. On the product specs you state:
[glow=blue,0,300]For the Laing pumps the followings features are integrated:
- Characteristics for the speed are fully configurable
- USB communication to the PC.
- Comfortable software for the configuration of the poweradjust USB
- Completely integrated into the software aquasuite [/glow]
I basically would like the pumps/fans to speed up to 100% when gaming and better cooling is needed and then spin back down again when not needed. The poweradjusts would also give the kick start to the DDCs as well.
Can someone tell me whether an aquaero and 2 Poweradjusts would be able to automatically control my pumps depending on the temperature parameters i enter to aquasuite?
I am pretty confident that the aquaero can do this for fans - i just wanted to check to see if it can do it for the DDCs as well. ;)
Thanks in advance.
Re: Clarification needed on poweradjustUSB and Aqu
Sonntag, 13. Mai 2007, 15:46
Welcome to the forum :)
The pumps can not be controlled by temperature.
There is also no way to connect the poweradjust to the aquaero.
cypriobrit
Sonntag, 13. Mai 2007, 16:01
Thanks for clarifying that Shoggy. ;)
