• 22.11.2026, 23:00
mitnick
More Aquaduct 360XT problems
Freitag, 18. Mai 2007, 10:47
Well I installed the baby but I've got a few problems. Firstly it appears that the LCD doesn't work on it. It neither lights up nor does the PC pickup that it is connected via USB. I've tried this with various cables and in different ports.
Secondly it appears that the fans do not work either. I've set the jumper on the card to both settings but it appears that there's no fans working.
Re: More Aquaduct 360XT problems
Freitag, 18. Mai 2007, 14:56
You should use the following jumper configuration:
FAN_JUMPER: open
J1_STANDBY: set
One exception: if you are using the StandBy connection the J1_STANDBY jumper must be open too!
