• 22.11.2026, 21:33
johnnytsunami
Aquasuite doubt.
Donnerstag, 21. Juni 2007, 06:18
Hi i just installed the new version of aquasuite under windows vista and when i open it, it doesn't show anything. It just displays the upper menu and the background(aquacomputer aquasuite).
Re: Aquasuite doubt.
Donnerstag, 21. Juni 2007, 14:34
Make sure that your aquaero, tubemeter, multiswitch or whatever you have is connected the right way.
SNIFFER
Montag, 25. Juni 2007, 02:43
Yes make sure you have connected your USB cables correctly, it is quite easy to believe you have done so. It works fine on my Vista PC.
edboswell
Montag, 25. Juni 2007, 15:01
I had the same problem... as sniffer said.. its quite easy to believe you have... when you actually havn't :P
