• 22.11.2026, 21:56
CDfreak
Aqua Computer heat pad
Montag, 2. Juli 2007, 23:34
Hello everybody
I just bought an AquaGraFX G80 waterblock for my Geforce8800GTX graphic card with it I got a blue heat pad with on both sides some kind of protective film (a dark bleu and white one).
I assume that when I install it I have to remove them both is that correct or do I need them?
Greetings
CDfreak
Re: Aqua Computer heat pad
Montag, 2. Juli 2007, 23:51
Welcome to the forum :)
Yes, you have to remove them. They are only a cover because these pads are self-adhesive.
CDfreak
Dienstag, 3. Juli 2007, 19:18
Ok thanks for your reply!
As soon as I have everything I can start to assembly my watercooling
Greetz
CDfreak
