• 17.11.2026, 05:11
optimadam
Aquaero, Multiswitch and pump controler
Dienstag, 4. September 2007, 23:54
I have all the names panels and want to link them all together but none of the cable come with it. So what do i need and where do i get them from?
Re: Aquaero, Multiswitch and pump controler
Mittwoch, 5. September 2007, 01:40
Cable for aquastream (70cm version)
Cable for multiswitch
Important: if you connect the multswitch to the aquaero, you will lose the ability to dim the channels via PWM. The channels will only work like a switch (on/off).
optimadam
Mittwoch, 5. September 2007, 10:55
Thats all i wont at the moment any how.whats the extension slots about?
Mittwoch, 5. September 2007, 11:03
Currently there is no use for it.
Future products could use it.
optimadam
Mittwoch, 5. September 2007, 13:25
So the best way to set it all up is by using the USB cable for the aquaero and multiswitch and then the aquabus cable to plyg the pump into the multiswitch?
Mittwoch, 5. September 2007, 15:55
Yes :)
Connect the aquaero and multiswitch via USB.
I would recommend to connect the aquastream to the aquaero because so you will be able to use it directly via aquaero and the aquaero can also detect malfunctions of the pump.
btw: it is no aquabus cable ;)
optimadam
Donnerstag, 6. September 2007, 23:45
My aquaero sets everything to yyyyyyy. Once i set everything my self, save it and turn the pc off and on again they reset and say "emergance shutdown".
Also my multiswitch comes up blank in the aquasuite and looks like its not active
