• 18.10.2026, 11:30
Ascubal
Problems using Aquastream XT Ultra and Flowmeter
Montag, 17. Dezember 2007, 23:22
If i connect the flowsensor through the Aquastream XT Ultra i get no value, it says 0,0 l/h..
And the under the " Pump and flow rate settings " the Flowsensor Active button is "pressed"
Calibration Value is 509 Impulses pr liter.
Number of measuring pulses is 8.
Anything wrong here?
If i connect i to the Aquaero it works fine.. The Calibration value there is also 509.. Is this right?
Re: Problems using Aquastream XT Ultra and Flowmet
Dienstag, 18. Dezember 2007, 09:25
After setting the pump input to flowmeter you have to restart the pump (power off/on).
Ascubal
Dienstag, 18. Dezember 2007, 15:10
Thanks, that helped :) But what about the impulses? is that right? I have the "old" flowmeter..
gr3if
Dienstag, 18. Dezember 2007, 19:06
Yep Impulse is right.
