• 29.11.2026, 11:40
JorisS
Aquaduct XT 360 leaking at top
Samstag, 15. Dezember 2007, 12:44
been experiencing problems with my aquaduct XT 360;
the plastic cover on the top, which is held in place by 8 screws and which is removed during the (re)filling process, seems to for some reason bend under the pressure or temperature of the water (usually between 22-28 degrees). Now the other day I noticed there was water coming out on both long sides of the cover, as can be seen on the picture below:
I don't know why this is, the screws are in as tight as possible. If I remove all screws and the plate, it is by no means flat. As far as I can tell the rubber seal ring is in proper place. Is this some kind of 'overpressure' protection of the system, or is something wrong?
Obviously not too happy with this...
Re: Aquaduct XT 360 leaking at top
Sonntag, 16. Dezember 2007, 02:13
No, there is something wrong.
I would recommend to use a new seal.
JorisS
Sonntag, 16. Dezember 2007, 20:48
Where do I get one of those?
(I guess from you guys, but how? Is it guarantee/service?)
But is it normal that the plastic top cover gets bent?
It's not flat at all.
JorisS
Donnerstag, 20. Dezember 2007, 23:57
Hello?
So yes I have problem - I'd appreciate some info/help in fixing it. Do you guys send out spare parts as a customer service? Should I send a mail to ask for it? What do I do?
Please let me know so I can lay hands on a new seal, and possibly a new plastic cover plate, one that's flat and hopefully stays that way :)
b0nez
Freitag, 21. Dezember 2007, 00:15
Please write a Mail to support@aqua-computer.de, this is the best way ;)
:rolleyes:
Freitag, 21. Dezember 2007, 12:47
You can buy any part as a spare part - no problem. Please write a mail.
JorisS
Samstag, 22. Dezember 2007, 02:27
Ok I wrote a mail. Probably not the best time of the year but it's not really urgent anyway. Just hope to get it fixed. Preferably without paying for it, as it just doesn't seem right that such an expensive unit shows defects after only a couple of months of usage.
JorisS
Freitag, 28. Dezember 2007, 23:38
So is everybody on holidays atm?
Haven't gotten a reply or anything as of yet
@re@50
AC is in Holiday till 07.01.08.
Max_Payne
Samstag, 29. Dezember 2007, 12:14
Ask www.aqua-computer-berlin.de Mr. Krumme is probably in the store and can help you.
Max Payne
JorisS
Freitag, 11. Januar 2008, 13:00
I would just like to update this topic by saying that I got a reply from AC, they have sent me spare parts free of charge :)
Just thought I'd write this here as homage - excellent service, this is what keeps your customers coming back!
Thanks!
