• 06.10.2026, 18:29
ScottishCaptain
Aquaduct 360XT Self Configurable?
Samstag, 26. Januar 2008, 12:19
Greetings to all.
I've got a quick question about the controller in the Aquaduct 360XT (Mark II I guess- whatever is the latest).
Is the unit self-configurable, or do you absolutely require the software running on the PC over USB, for the Aquaduct to operate properly?
I've read that the unit inside the Aquaduct is a Aquaero controller- or some variant. The Aquaero has a fairly thick manual and you can seemingly configure most of it's operation via the LCD panel (without using the USB connection).
So, is the Aquaero inside the Aquaduct a TRUE Aquaero controller- can I configure most of the aspects of the Aquaduct's operation from it's front LCD panel, or do I absolutely require the software to be running on my PC?
The guys who reviewed the unit in english over at Virtual-hideout.net seemed to mention that it was heavily reliant on software and would overheat without it. I don't know if they knew what they were talking about, or if that's true, and the Aquaduct isn't configurable unless you install the software.
Cheerio.
-SC
gr3if
Re: Aquaduct 360XT Self Configurable?
Samstag, 26. Januar 2008, 13:45
You can do all settings via the 3 plugs on the aquaero. the software is easyer to use but it works.
ScottishCaptain
Samstag, 26. Januar 2008, 23:02
Okay, that's what I wanted to know.
I just wanted to make sure that it was a real Aquaero sitting in there, not some slimmed version.
Thanks again.
-SC
gr3if
Sonntag, 27. Januar 2008, 13:09
Its quite a bit different because u can use one fan header inside the pc. Functionwise its not different to the normal version.
