• 05.10.2026, 07:29
edboswell
Problem with aquaero/aqua suite
Freitag, 25. Januar 2008, 18:50
Hi I have many problems with my aquaero/aqua suite and I am getting fed up!!
1) I don't even have a water level dector but yet on the aquaero it says "Shut down in (then a count down)" "Level too low"...
2) The aquaero lettering is proper messed up on both ends (kind of like ghosting/letters over letters etc.)
3) I open up the aquasuite and I get this message:
Exception: InvalidArgument= Value of 266 is not valid for SelectIndex etc etc....
4) When aquasuite does show up the aquastream XT tab rairly works.
5) On the aquaero (when it works) I get a flow meter value of something like 800 liters an hour... when in actual fact it is more like 30. (This is probably a aquastream XT problem).
I have done all the 'normal' things like check all paremeter values, reinstalled the aquasuite several times eprom reset etc etc...
If need any more info, then ask and I will provide.
Thanks
Ed
PS I am running Vista with the latest firmware on all hardware from aquacomputer.
edboswell
Re: Problem with aquaero/aqua suite
Montag, 28. Januar 2008, 12:51
Should I contact support or just wait here?
gr3if
Montag, 28. Januar 2008, 16:12
Okay: Please make an EEprom rest, reinstall the Aquasuite und disconnect the pumo from the Aquaero to get started. Afterwards make clear, that everything is running then reconnect the pump to the aquaero.
