• 09.10.2026, 15:25
cka3o4nuk
Aquastream XT USB 12V (silent?)
Dienstag, 5. Februar 2008, 22:03
i had a such loop
cuplex di 1\4
Aquacomputer-cuplex-PRO-Rev--3 on the northbridge
and Aquacomputer-cuplex-PRO-Rev--3 on the video//
aslo some custom blocks on audio amlifier ... and on the mb pwm
+2 rads airplex pro 360
now i am using laing ddc pump and it is to loud at 12v
is Aquastream XT USB 12V silent at the full speed?
pharao
Re: Aquastream XT USB 12V (silent?)
Dienstag, 5. Februar 2008, 22:13
yes, it's silent.
and it is absolutely sufficient for that loop (just in case that question comes up ;))
cka3o4nuk
Dienstag, 5. Februar 2008, 22:19
oh so one more question
a had a 1046((ceramic))pump and after a month of use it became to produce a noise (
wouldnt Aquastream XT USB 12V broke like this?
pharao
Dienstag, 5. Februar 2008, 22:24
no it won't.
if you still have the 1046, try the Eheim MOD, if it's silent then, you've saved some money :)
the eheim mod fixes the blade wheel and it will make less noise.
cka3o4nuk
Dienstag, 5. Februar 2008, 22:36
i made a mod but no diferent so ill order the aquastream and hope it woudnt become laud
gr3if
Mittwoch, 6. Februar 2008, 00:50
You can order every part of the Eheim 1046/ Aquastream seperatly so normally if your Eheim 1046 is broken fix it.
