• 01.12.2026, 00:06
Tenfold
Aquastream XT Ultra Setup
Montag, 10. März 2008, 03:26
I am looking to build a dual loop system and was looking at this pump. I was wondering how to go about setting up two as far as monitoring. Are these pumps able to show the information directly from the computer with only Aquasuite? Sorry for the silly questions but I am not familiar with any of this really. I was just wondering what I would be missing out on not using the Aquaero as my case is very small and I will be going with external wc setup.
gr3if
Re: Aquastream XT Ultra Setup
Montag, 10. März 2008, 12:56
The pumps are conencted via Usb cable. If you hve two pumps you have 2 usb cables and every pump shows up seperatly in the aquasuite.
IF you then have an aquaero you can connect the pumps via an y-cable to the aquabus and the pumps will show up in the aquaero tab and you can use the thermal sensors too.
Tenfold
Montag, 10. März 2008, 14:24
Thanks for the info much appreciated!
