• 07.10.2026, 02:29
cypriobrit
USB Poweradjust setup
Sonntag, 20. April 2008, 20:07
Hey all.
Im just about to set up 2 USB Poweradjusts to control my 2 laing ddc pumps. I think i have the USB, Power, Pump RPM connector set up properly but i wasnt sure about whether i need to add any jumpers?
Can you adjust everything via the software anyway without using the jumpers? The only one i thought i might use was the de-aeration one to bleed the loop of air first. Can i deactivate it after though without having to remove the jumper manually?
The other question i had was the speed signal output - what do i gain if i connect this to my aquaero?
Thanks
Cyp.
Re: USB Poweradjust setup
Montag, 21. April 2008, 15:46
You don't need the jumpers. You can configurate/control everything with the aquasuite software.
The jumpers are useful if you want to load another profile without starting the aquasuite software.
Connecting the speed signal to the aquaero could give you information if everything is running. If no signal is available you can set an alarm or shutdown the system etc.
