• 22.11.2026, 23:48
New: aquadrive quad copper edition
Sonntag, 17. Februar 2008, 23:10
Our hard disk series aquadrive has a new baby:
The aquadrive quad copper edition
This hard disk cooler can take up to 4 hard disks which are cooled and decoupled very well in the completely encapsulated case. Merely three 5 1/4" bays are used and the cooler contains a fluid reservoir at the same time, this one has a greater capacity than the aquatube.
This new star of our hard disk series uses delrin as case material which takes vibrations better than aluminum due to its structure. Solid copper plates are used inside. Their weight approximately corresponds to the weight of an aquadrive dual aluminium. In turn these are surrounded by a water jacket which also takes and lowers vibrations. The whole aquadrive is kept in the already approved rubber components which decouple it from the case. The inside of the case is provided with a special layer covering to take high-frequency noises.
To be able to take SATA and ATA plates without too big case openings, the openings are executed ex works for SATA as of now and can be used for ATA drives by breaking them out.
The integrated fluid reservoir is filled by an enclosed squeeze bottle at the front. By two tubes the two reservoirs are communicating with each other so that the filling level compensates itself. The current water level can comfortably be read in the right profile. A little red ball indicates the fill level.
The aquadrive quad will be available at the end of the month for approx. EUR 130.
The connections are G1/4".
Material: delrin/copper/stainless steel
Designed for four hard disks in three 5 1/4" bays
Capacity of the reservoir: 250 ml
Here a few photos:
Top_Nurse
Re: New: aquadrive quad copper edition
Samstag, 23. Februar 2008, 03:05
Nice piece of work here! When can we see it here in the states?
How about an internal view of the water channels?
heed
Samstag, 23. Februar 2008, 14:39
Whoa, I really like it! Great job.
I second the request for pics of the channels.
Gosh, that will be quite expensive in USD. :-[
gr3if
Samstag, 23. Februar 2008, 14:47
130 euro around 200 usd.
Top_Nurse
Sonntag, 24. Februar 2008, 02:34
I think the proper term is relatively expensive. However, the old dual Aquadrive was about the same price so it seems to me to be cheaper for more utilization. ;D
Also with copper and Delrin being used the naysayers must be having a fit of apolexy about right now. ;)
I'm thinking I have 4 Raptor harddrives that would look nice and cool. ;D
edboswell
Sonntag, 24. Februar 2008, 16:55
4 raptors... kind of a set back in terms of noise?
heed
Montag, 25. Februar 2008, 07:26
Right but we have no idea when/if/how much it will be in the US. :-[
TN, maybe you could buy one of these and finally finish Feeding Frenzy! ;D
Cobra88
Montag, 3. März 2008, 17:47
Hi Shoggy
Any plans for a Black front version ?.
Regards
Rick
gr3if
Montag, 3. März 2008, 18:11
Black front maybe in August by Ac-Berlin and not regular.
Top_Nurse
Montag, 10. März 2008, 01:16
Well now that I am back to making some serious amounts of moula it's time to redo Feeding Frenzy! Thinking also of a 8800 GTS card for one of the new coolers and it will also be an AMD. ;D
We will know soon what it costs here as I just ordered one from Sharka.
migueld
Samstag, 26. April 2008, 03:16
Hey TN! It's nice to see you around. Hey do you know when Sharka will bring these quad HDD box? These are very tempting...
