• 20.11.2026, 03:06
SpeedyGonzales
aquabus Y-Adapter für aquastream XT
Samstag, 12. April 2008, 04:33
Can someone explain what I can use this for?
Aquaaero has only one aquabus, and I use it for the Aquastream XT Ultra.
Can I split the aquabus on my aquaaero so I can connect my tubemeter to my aquaaero?
Produkt kable is this:
[53063] Aquabus Y-Adapter für aquastream XT
Regards
Speedy
PS: I think there can be more illustration/examples on how to connect the system together!
pharao
Re: aquabus Y-Adapter für aquastream XT
Samstag, 12. April 2008, 10:05
you can connect up to 127 devices to the aquabus. in order to do so, you need these Y-adapters. you can e.g. connect a tubemeter and several pumps.
SpeedyGonzales
Montag, 14. April 2008, 15:51
So you can connect upto 127 devices.....wow...
So for me to have the tubemeter on USB is just crap.
Does it use the yellow pin at all, or just black and red?
Can I make a one to many instead of 1 to 2 (Y)?
SpeedyGonzales
Sonntag, 20. April 2008, 14:34
Can not get Y connector to be stable.
Devices apperas for 1 second, then disapperas again.
Very unstable.
Any good description to how to do this?
When using Y cable, aquaero says firmware in pump to old??
Speedy out
Sonntag, 20. April 2008, 14:36
Which firmware versions are you using?
It's higly recommend to use the latest version on all devices.
SpeedyGonzales
Sonntag, 20. April 2008, 15:38
Aquastream 1011
Aquaero 4.19
AquaTube 1.07
Tried to use Y cable on Aquaero with tubemeter and Aquastream connected.
Aquastream was VERY unstable!
Aquastream was also connected to USB, is that a problem?
Also tried to connect multiswitch to Aquaero, and Aquastream and tubemeter on multiswitch aquabus, but no luck.
Is only red/black in use, or does it use yellow too?
Speedy out
Sonntag, 20. April 2008, 18:31
It uses all three wires.
SpeedyGonzales
Montag, 21. April 2008, 03:03
Then I expect my Y cable is not correct.
As in the picture for your Y cable, I have 1 connector which get 3 cables, and 1 conncetor which only have 2 (red/black)
I have already ordered from you Y cable, so I will wait, and try again.
Speedy out
SpeedyGonzales
Freitag, 2. Mai 2008, 09:53
It works with the Y-cable ;)
