• 13.10.2026, 03:30
cka3o4nuk
aquastream XT USB Pumpe
Samstag, 17. Mai 2008, 11:18
hello
i have such a problem ....
a pump 1 month old bought aquatuning.de
i disabled the led in the software and now its blinking and pump start only after a few minutes...
also a question
to activete deaeration mod i need to set jumper(on the ext temp coonector)?
thanx for your support
Jogibaer_Nr1
Re: aquastream XT USB Pumpe
Samstag, 17. Mai 2008, 22:54
What Firmware is on the pump?
Few minutes is too much logically.
1. Try to set up the jumper in the ext. temp connector pins THEN start the aquastream with the jumper on these pins....on this way you reset the firmware....
To activete deaeration mod you do it like you said, BUT WHILE the aquastream is running.
when the problem still exists, try to flash a new firmware, 1.17 is the newest.
Do you have an aquaero? When not, do it like it's explained here: http://forum.aqua-computer.de/index.php?…&threadID=92683
with the selfmade flasher
