• 26.11.2026, 12:44
Sufu
Aquagfx g92 installation?
Freitag, 30. Mai 2008, 20:04
Is there a manual for the AquagraFX 8800 G92? I got the waterblock, but the instructions are in german :(
I'm not sure which parts I need to put some artic silver on. So far I did all the memory chips and the GPU, but there were no pads or anything else included with the block.
gr3if
Re: Aquagfx g92 installation?
Freitag, 30. Mai 2008, 23:27
Normally u should use the Pads on the original Ram and only bring the wlp on the gpu.
This would be the manual. Also you should use all screws that are included with the graphic card.
Sufu
Sonntag, 1. Juni 2008, 19:44
I tried using artic silver on the RAM and GPU, then the thermal pads on the voltage regulators. After putting everything together the screen was corrupted at POST so the card was unusuable.
I am not sure if it's because the waterblock does not make full contact with the RAM chips and the card got fried, or it was bad to begin with.
Anyone have the g92 block on a 8800 GTS?
MUFFDIVER
Montag, 2. Juni 2008, 06:51
The chip wud not have fried on immediate install and firing of PC.
IDK but seems mb it was fubar before install :-/
Just my 2c thou
