• 30.09.2026, 13:50
SteinerKD
Flowsensor, where in loop?
Samstag, 28. Juni 2008, 01:33
Where in the cooling loop do people usually put the flow sensor? Just before or after the pump, or somewhere in the middle of the loop?
Just after the pump I guess gives you a start valu of how much it's putting out. Just before the pump the flow of the system with all bottlenecks passed etc..
Or doesn't it make a difference?
elanee
Re: Flowsensor, where in loop?
Samstag, 28. Juni 2008, 01:49
shouldnt make a difference i think but a smart spot to use it would be on ramslots if you cool your ram.. then you loose minimum flow from the sensor:)
since the water is going arround in tubes i guess the pressure would be the same all arround
pharao
Samstag, 28. Juni 2008, 09:53
it makres no difference at all, since the flow will be the same at every (!) spot in the system.
SteinerKD
Samstag, 28. Juni 2008, 13:27
Ok, guess that's logical. No system has better flow than the slowest bottleneck.
