• 23.11.2026, 00:41
wholehog439
8800gt
Sonntag, 20. Juli 2008, 19:21
I have a water block for my 8800gt. When i take the heatsink off there is thermal pads on the ram chips, do i need to use these with the waterblock or can i put thermal past on them. Do i need to use thermal pads on any other parts when installing this waterblock
thanx alot
MUFFDIVER
Re: 8800gt
Montag, 21. Juli 2008, 18:12
Hmm i took mine off and used paste and i have had no problems... But if you left the thermal pads on i would say it wouldnt really make a diffrence.
Hope that helps ;)
M3rl1N
Re: 8800gt
Montag, 21. Juli 2008, 18:53
often its better if u leave those pads on the ram chips because they are also used as spacer - the paste isnt that thick then the pads u know...
