• 09.10.2026, 05:28
Jexx
[prob]Aquaero doens't make 2nd Fan rotate
Freitag, 12. September 2008, 11:58
After a hard day of work I managed to connect everything up to my aquaero. I booted up my system and my first notice is that the Aquaero only manages to make my fan on FAN1 channel rotate .All the other fans work perfect directly connected to the PSU, but not if they have to pass the Aquaero.
On top of that... i can see that the LED's in my fan swork if they are connected through the Aquaero. So the fans do get power etc, but don't rotate.
I have tried switching the FAN connections and everytime it's the same thing only the FAN on channel 1 rotates and the other only the LED's work.
Any suggestions to make this work.
[ + ] Immortality is only for those who are fit for it. [+]
drbo
Re: [prob]Aquaero doens't make 2nd Fan rotate
Freitag, 12. September 2008, 16:21
This could be due to your sensor settings for fan2. Need more info to help you.
A screen shot of fan2 settings would be nice :)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
Jexx
Freitag, 12. September 2008, 19:02
Ok,
here is a screenshot. I think i have set everything right.
If i press the "Start test" button to test maximum RPM it doesn't move either... just so you know.
Screenshot
Jexx
Samstag, 13. September 2008, 13:58
I have also discoverd an other problem last night.
If i connect the USBwire between the Aquaero and my motherboard. I have a small chance of running my system for 5min and then everything blocks, just freezes for 50% of the time or just powers off.
I have rechecked the wire connection for like a 100 times and iem 101% sure i got it right...
I'm currently try'ing to just give 1 fullpower line to the aquaero ( modular PSU ) because i'm thinking that there is a powerflaw somewhere.
EDIT: my last test works out it seems, I had to dedicate 1 powercable to the aquaero. I still have the USB cable problem though.
EDIT2: nope it doesnt work anymore now... I'm even in doubt if the Aquaero is stable? Since i have put the thing into my computer, troubles all the way. LED's don't work anymore, PC just shuts down. all kind of stuff. I don't even know where to start -.-
Steensen
Samstag, 13. September 2008, 17:08
This sounds like an ordinary short circut problem someware in the system.
Regarding your fans not rotating, it's because your settings make the aquasuite set the rpms very low, and thus too low for your fans to rotate, but high enough to make the LED's light.
So eather set the temperature settings lower, change the scale, or just plainly set the RPM's manually to a number, or the output to a certain percentage.
Jexx
Samstag, 13. September 2008, 19:06
Short circut is my biggest guess to... but where?
I don't have the propper equipement to check it all..
About the fan, the weird thing is that it won't even rotate when i do the rpm test. :/
Steensen
Samstag, 13. September 2008, 22:22
Have you tried switching the fans around, so that different fans have been connected to the FAN1, and running?
How are the surface the wires are laying on?
Jexx
Sonntag, 14. September 2008, 14:34
I have found my fan problem now. The wire didn't seem to make a good contact with the connection pins. Did some magic on them and they work now.
Cheers for the help steensen.
Still have my USB problem though... :/
On top of it all vista is realy working against me now... crcdisk.sys problem just affected me -.-
Try'ing to recover my data and reinstall the whole thing... :/
