• 30.09.2026, 06:27
ligoman17
Multiswitch Black Faceplate
Dienstag, 28. Oktober 2008, 07:47
Hello,
I am wondering if AC makes a black faceplate for the Multiswitch?
drbo
Re: Multiswitch Black Faceplate
Dienstag, 28. Oktober 2008, 10:47
This is a returning question ... http://forum.aqua-computer.de/index.php?…d&threadID=1122
and I cannot understand why the answer still is NO.
But, there is a way around the problem, as I have shown before.
But you can drill holes in a frontplate for aquadrive, (2mm and 3,5 mm holes if I remeber correctly) as I did ...
[img]http://www.diskusjon.no/index.php?act=attach&type=post&id=211472[/img]
The only problem with this solution is that the 4 pre drilled fixing holes dos not fit, so after drilling new holes, the old ones might show a little ...
Caliber has also done this sucessfully http://forum.aqua-computer.de/index.php?…d&threadID=1252
drbo 8)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
