• 08.10.2026, 04:52
Isdes
A question about flow rate
Dienstag, 28. Oktober 2008, 01:49
Hey guys I’m new to water-cooling and I got a question that I hope you can help me with.
I just got my Aquaduct 240 Pro Mark II, AC Cuplex XT di and AC aquagraFX GTX 280. Hardware installation went fine but when I installed aquasuite 4.64.00 I see that the flow rate is 0.00! Did I miss something? What should I do about that?
fox3
Re: A question about flow rate
Dienstag, 28. Oktober 2008, 03:27
Is there a flow sensor in the loop? I am not sure the aqua duct 240 has one.
Isdes
Dienstag, 28. Oktober 2008, 06:16
I thought the Aquaduct 240 Pro Mark II would have a build-in flow sensor. I didn’t add a flow sensor myself. I can disable the ‘Flowsensor connected’ option in the picture above and it will then ghost the Waterlevel options at the bottom – should I do that?
So far I am very impressed with AC’s water-cooling but I sure could use a detailed manual to the aquasuite software …
Dienstag, 28. Oktober 2008, 11:38
The aquaduct 240 has no integrated flow sensor. The sensor is also necessary to meassure the fill level.
But you can connect an optional flow sensor.
