• 14.10.2026, 02:12
Beun
CoolCurrent > 450 Watt?
Montag, 31. Mai 2004, 19:20
Will a CoolCurrent with more than 450 Waat be available in the future?
Heimwerkerking
Re: CoolCurrent > 450 Watt?
Montag, 31. Mai 2004, 19:36
I don't think that there will be a CoolCurrent with more then 450Watt. There is no need for it. Every normal System cant run with less thenm 450Watt.
Zitat von »454-bigblock«
Beun
Montag, 31. Mai 2004, 19:37
The new videocards require more power.
Seppentoni
Montag, 31. Mai 2004, 19:46
who says that ??????
i think that the mostly needed power was 350 W
Es gab eine Zeit vor der Zeit, als es noch keine Zeit gab .... *muharharharhar*
kampfsau
Montag, 31. Mai 2004, 20:01
450W = overkill ::)
i´m running a AMD64-3200+ system with an ATI 9800pro, 2 optical drives, harddisk, waterpump etc with an old 350W enermax and there is still power to spare ;)
even 400W-PSUs are way over the top... and the new GF-6800 cards may have two power connectors, but the power intake is not that high
they only need the double feed to have a stable voltage :)
i´d reckon even a 300W-PSU would suffice for up-to-date systems as long as it´s good quality!
Beun
Montag, 31. Mai 2004, 20:04
I red somewhere that for the new cards 350 Watt is a minimal but 420 is recommended. I also think that it is good to be prepared for the future (especially with such an expensive psu).
S.K.U.L.L
Montag, 31. Mai 2004, 20:46
Well, 350W is not equal 350W. I think the grapic card need the power from the 12V-Bus. You have to look in the manual of your PSU. Enermax are very powerful on this bus.
Frage: Wieviel Eier passen in eine Hundehütte wenn ein U-Boot bei rot über die Kreuzung fährt?. Antwort: 32, weil Joghurt keine Haare hat.
CyberXY
Montag, 31. Mai 2004, 20:51
a few month ago I had i defekt PSU. so I ran a AMD 64 3000+, 2 Hard disks,2Optical devices,a radeon 9600 ViVo and some other kards like Soundcard etc. with a high quality psu which had only 230W, because I dind't have enaugh money to buy a new one
it doesn't matter how many W a psu is said to have, but how many W it really has.
zonoskar
Dienstag, 1. Juni 2004, 18:24
Still, it would be nice to have a >450W PSU since my Xeon board requires at least 450W running 2 2.8 Xeon CPUs. Add a GF6800 or X800 to that and you see the need for it.
This space for rent...
S.K.U.L.L
Dienstag, 1. Juni 2004, 18:51
Well, dual xeon is overkill, isn't it ???
zonoskar
Dienstag, 1. Juni 2004, 21:53
Not for me, MPEG encoding is 90% faster with 2 CPUs compared to 1 CPU.
mesa
Dienstag, 1. Juni 2004, 22:20
Hm.. do you have an MPEG Factory or what? It takes me about 2h to encode one movie. that's fast enough for me :)
S.K.U.L.L
Dienstag, 1. Juni 2004, 22:25
It is easy: He has to much money ;D ;D ;D
thetruephoenix
Dienstag, 1. Juni 2004, 22:33
nvidia may recommend a 350 watts psu for their new cards...
...but amd said the same about their processors some years back then. the system said above can even run with a 250 watts psu. the recommendations are referring to noname psus.
the coolcurrent has more power to offer than you will need in conceivable future...
Beun
Mittwoch, 2. Juni 2004, 21:38
Still if a 450+ Watt PSU would be available I would buy it directly. Is there any chance this will happen in the future?
S.K.U.L.L
Mittwoch, 2. Juni 2004, 22:09
i don't think so :o
But nobody can see the products and features in 2 years....
"THE HOPE DIES AT LAST" ;D ;D ;D (Ich hoffe das heisst im Englischen so ;D)
CU
Skull
Jogibaer_Nr1
Mittwoch, 2. Juni 2004, 22:57
@S.K.U.L.L.! Das heißt "The hope dies at least" ! *kopfschüttel* ;D
kampfsau
Mittwoch, 2. Juni 2004, 23:15
endlich stirbt die hoffnung??
mindestens die hoffnung stirbt?? ::)
also leute, euer englisch...
"HOPE DIES LAST"
das wars, mehr nicht
setzen! ;)
Beun
Donnerstag, 3. Juni 2004, 00:33
der_fetti
Donnerstag, 3. Juni 2004, 11:45
Immer die lustigen 1:1 Übersetzungsversuche... ;)
