• 07.10.2026, 23:04
gezzas525
Airplex EVO 1800 VS EVO 360 (heat dissipation)
Mittwoch, 11. August 2004, 20:01
Iam assuming that the 1800 doesnt need any fans, i mean 15 fans (120mm) is rediculus. What kind of performance does it give when used as a passive radiator vs the 360 (using fans).
Most 360 radiators iam told can dissipate anything between 200W-600W, how much heat can the 1800 dissipate (passively cooled).
Kleo
xx_ElBarto
Re: Airplex EVO 1800 VS EVO 360 (heat dissipation)
Mittwoch, 11. August 2004, 20:10
the 1800 is 5 times as big as the 360 so i think it can dissipate a lot of heat ;D
but for "normal" system (anything that fits in a tower ;)) there is only a low temperature difference between the 1800 and the 360 (both passive)
if you put fans at 5v at the 360 you should get really better temps than the passive 1800
gezzas525
Mittwoch, 11. August 2004, 22:23
Thats what I thought aswell, unless of coarse you equip the 1800 with fans. 120mm and larger! ;)
