• 18.11.2026, 12:08
PTK@FIN
Aquatube + bubbles 'problem'
Donnerstag, 12. August 2004, 18:22
Is there any easy way to make the aquatube form LESS bubles than its doing now. There is a line of bubbles going out of my pump line [ clearly visible ] and i would like to get rid of that.
Tested a bit and its because the flow rate in aquatube is so damn high that thesres allways full of bubbles and then those bubbles gets sucked into the pump.
My setup
Aquatube->Pump->CPU block-> radiator -> Aquatube.
The thing is that my setup is now like this
Quellcode
1
2
3
4
5
6
7
8
9
P  &#124;                 &#124;--   <= in line
L  &#124;                 &#124;--   <= light
E  &#124;                 &#124;--
X  &#124;------------&#124;
        &#124;  &#124;   &#124;
            \ to pump
Its gonna be in that 5 1/4 holder in my case front. That IN line i can pretty much change any way i want... means a complete rebuild of my system so not happy to do it.
A EASY way to make it better.. not that its really that bad, but hey.. any bit helps :D
Thnx in advance
PTK
Re: Aquatube + bubbles 'problem'
Donnerstag, 12. August 2004, 20:11
Have you tried to put the in-line under the water level? You could use the lowest connection instead of the highest as you do it right now.
pharao
Donnerstag, 12. August 2004, 20:22
more water ;)
