• 27.11.2026, 11:18
AP2
aquaero 5 XT Work with MAC OS X (Hackintosh)
Mittwoch, 7. Dezember 2011, 09:36
Im currently building a watercooled hackintosh and would like to use the Aquaero 5. Does anyone know if this would work with MAC OS X?
thanks!
Mittwoch, 7. Dezember 2011, 12:19
No, the aquasuite only runs on Windows XP and above.
Of course you can also use the aquaero XT without the software since all options are accessible through the device itself.
AP2
Mittwoch, 7. Dezember 2011, 16:29
thanks for the speedy reply!
mm67
Mittwoch, 7. Dezember 2011, 20:59
You can also run Aquasuite on a virtual Windows machine, this is my system running Aquasuite on virtual Windows 7 machine from OS X Lion.
AP2
Samstag, 17. Dezember 2011, 11:57
NICE! Totally didnt even think of that. Whats youre setup?
mm67
Samstag, 17. Dezember 2011, 15:22
Gigabyte GA-Z68XP-UD4 & i7-2600K & Radeon HD6870 running OS X 10.7.2. Watercooling gear is controlled by AE 5 LT and a PA2.
