• 15.11.2026, 09:20
aphasia
Aquaero 5 XT (Aquasuite 2012) - High Memory Usage?
Dienstag, 27. Dezember 2011, 01:34
just noticed that my of copy Aquasuite 2012 is a bit of a memory pig...
is this normal? its using almost as much memory as firefox with 6 windows/40+ tabs...
glad i bought 16GB RAM for this build (only 2 sticks in atm, think i have a bad stick thus only running 8GB).
Phatboy69
Dienstag, 27. Dezember 2011, 07:12
They discovered a memory leak which will be fixed in a later update.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
aphasia
Dienstag, 27. Dezember 2011, 18:08
that's good because...
woke up my PC today, watched a clip and glanced at task manager...
