• 12.11.2026, 17:15
SoMBrA
Flow Sensor measurements needed!
Freitag, 20. Januar 2012, 15:19
Hello everyone, I would like to kindly ask to any owner of a Flow Sensor to tell me the size of the whole "block".
I really need to know the width (without any fittings) and the height, depth is not need since I won't have any problems with that :)
Thanks you very much :thumbsup: :thumbup:
Nihil Simile
Freitag, 20. Januar 2012, 17:38
The Aqua computer high flow Sensor # 53068 Is 53.00 mm wide this was measured from the side that the fittings screw into. By 49.70 mm, By 29.60 mm thick.
