• 20.10.2026, 08:13
iBeta2
Aquaero5 Software Sensor Data Source and AIDA64
Montag, 14. Januar 2013, 00:43
Aquaero5 Software Sensor Data Source misses One Disk FromAIDA64.
Have 4 identical disks in 2 RAID0 setups. Can see all 4 in AIDA UI, however 'Aqua Computer Service - Software Sensor' Dialog only shows 3.
Worse, is that the Aquasuite 1012 UI shows all 4 disks receiving input.
Have tried Uninstalling Service, but no luck.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »iBeta2« (14. Januar 2013, 00:49)
Montag, 14. Januar 2013, 07:58
I think aida not export the sensor data to WMI.
The aquasuite/service can only see sensors they are listed in the WMI exports from the Source Software.
iBeta2
Dienstag, 15. Januar 2013, 13:51
Yes that is correct, thanks.
I had been looking in the wrong AIDA Page (Logging instead of External Applications).
It would still be very nice if Aquasuite could give some indication of this - it should surely be technically possible since the Service knows that there are only 3 devices supplying the sensor information - and Aquasuite knows there should be 4.
