• 22.11.2026, 20:50
lxxl
question for Aquacomputer D5 pump mechnics with USB, sensor for flow and temp
Dienstag, 17. September 2013, 21:02
I am considering to buy a Aquacomputer D5 pump mechnics with USB (Manufacturer's ID:41093), but I need to ask a few questions before I decided to buy.
1. Does this pump has a built in sensor for flow and temperature? because I need water flow and temperature shown in a program, which in this case, the Aquasuite.
2. I need these numbers from flow and temperature shown at my windows toolbar below, can aquasuite do this?
3. If just the USB D5 pump can't do this, what modules do I need to have flow and temperature shown at my toolbar?
Thanks
Pilo
Mittwoch, 18. September 2013, 08:04
1. No & No. But you can connect an optional external 10k Ohm NTC sensor to the pump.
2. Not yet. Perhapse in the far faaar future, who knows.
3. You could search the internet for a toolbar programm that can handle the Aquasuite XML-Data-Files.
lxxl
Mittwoch, 18. September 2013, 09:45
Thanks for the info Pilo
