• 29.11.2026, 04:02
garyd52
2 X laing ddc 1t pro and poweradjust 3
Dienstag, 18. November 2014, 09:56
Hi , I have a quick and simple question I need answered , can I run 2 Laing DDC 1T Pro 10 Watt pumps from an Aquaero 6 and one Poweradjust 3 ultra with passive heatsink and do I simply need a Molex Y splitter cable to do this already having 2 AC Laing DDC pump adaptor cables ? thanks in advance , Gary .
Dienstag, 18. November 2014, 11:24
Using two pumps on one channel is not recommend. It might work but you will have to try it.
garyd52
Donnerstag, 20. November 2014, 14:00
Ok thanks Shoggy, I have 2 poweradjusts and the 2 laings already up and running with an Aquero 6 but thought i'd see if I could reduce the number of components i'll leave it as it is thank you for the info .
