• 10.11.2026, 10:56
Rex
Installing Quadro and splitty 4
Freitag, 28. Dezember 2018, 17:21
Looking for a bit of advice. I tried setting up the quadro and splitty 4 on my sons computer to run a couple of Corsair LL120 fans. The problem was that when the quadro was hooked up no other fans would start. As we were just testing there was not a screen hooked up.
It is a gigabyte z370 aourus gaming motherboard. The quadro was attached to the usb header.
Any advice would be appreciated.
avictord
Freitag, 18. Januar 2019, 07:38
HI Rex,
Surprised that you have not got a response.
How did you set up Aquasuite software to manage the QUADRO? If you describe this and some screen shots then that may prompt some help.
Cheers.
