• 13.11.2026, 19:19
Lucky75
Aquero configuration
Mittwoch, 19. August 2020, 09:09
Hello guys,
I have 4 Splitty 9 FAN splitters and 28 fans installed there.
The configuration is like that:
1. Splitty 9 - 8 230 mm BitFenix fans
2. Splitty 9 - 8 140 mm Silent Wings 2 up to 1600 rpm -PWM
3. Splitty 9 - 8 140 mm Silent Wings 2 up to 1600 rpm -PWM
4. Splitty 9 - 4 140 mm Silent Wings 2 up to 1600 rpm -PWM
How to configure Splitty's and Aquero to have all FANs between 300 and 500 rpm ?
Mittwoch, 19. August 2020, 10:04
Set up your outputs for for your range:
and then your controller (example curves):
100%= Max range, 0%= Stop or min
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »EnigmaG« (19. August 2020, 10:06)
