• 30.09.2026, 12:02
turgin
USB vs Aquabus
Sonntag, 20. September 2020, 20:47
Hello,
I have an Aquaero 6LT, a USB high flow sensor, and a D5 NEXT. I know I need the USB for the flow sensor and NEXT connected for setup and updates but are there advantages to connecting them to the Aquaero via Aquabus? Can I have both the USB and Aquabus connected to each simultaneously?
Montag, 21. September 2020, 04:39
Aquabus does not need any software, you can use values in the Aquaero from the other devices even if the AquaServer is not (yet) running
Yes you can.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »EnigmaG« (21. September 2020, 04:41)
