• 30.11.2026, 22:29
alexkyriak
Add Curve Controller Greyed out
Montag, 1. August 2022, 00:16
Hi all, I am editing the controllers, and the Add Curve Controller option is greyed out. Anyone know why this would be? Thanks.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »alexkyriak« (1. August 2022, 00:17)
WinstonWoof
Montag, 1. August 2022, 07:44
My Guess would be you have a non PWM device connected
Montag, 1. August 2022, 09:10
The device has a limited number of controllers for each type. You have the maximum number of curve controllers already in use.
alexkyriak
Montag, 1. August 2022, 23:45
Thanks guys. Yes, that's exactly it, I deleted another controller, then the option was available again, so yes, seems to have reached the limit of number of controllers.
