• 22.11.2026, 21:49
X-t-r-e-m-e
Aquaduct/Aquasuite and Samurize
Dienstag, 25. März 2008, 00:45
Hi there, I really need some help with Samurize.
I installed version 1.64.3 (latest version)
I placed the Aquacomputersamurizeplugin.dll into the correct plugin folder of Samurize.
I left aquasuite, which works fine, running in my traybar.
When I make a new meter in Samurize I can select the aquacomputer plugin and select getaquaductdata.
Then I enter the serial number of my aquaduct mkII which is 0XXXX.
After I enter the update interval 5 or 10sec and last the parameter to read, in this case Sensor1.
The only reply Samurize gives is that the parametername is incorrect.
I cant get it running, what am I doing wrong here ?
taloche_aqualite
Re: Aquaduct/Aquasuite and Samurize
Dienstag, 25. März 2008, 13:00
