• 30.11.2026, 21:45
jbocapone
Strips work..fans work but no leds..what happened?
Freitag, 13. März 2026, 10:33
got a new farbwerk 360..updated aquasuite..running a splitty 4 with 3 Corsair LL120s..no argb on fans now.strips work..fans dont
Dienstag, 17. März 2026, 14:15
Check that one of the three fans is on port #1 on the splitty4... it is the only port that reports RPM.
Remayz
Mittwoch, 18. März 2026, 00:02
same for the RGB. if you have 3 fans they have to be on ports 1, 2 and 3. they are all daisy chained and start at port 1. if port 1 is not used, nothing should work.
