• 12.11.2026, 21:10
chaltharr
Pump vibration dampening
Sonntag, 23. November 2008, 00:05
This has probobly been asked once or twice before but i have been unable to find it. What is the best way to silence the Aquastream XT pump hum (vibration)?
PsiQ
Re: Pump vibration dampening
Sonntag, 23. November 2008, 01:23
chaltharr
Sonntag, 23. November 2008, 11:59
Thank you for getting back to me this quick. i think i can guess that the orange part is some sort of rubber sponge. but what is the black parts?
pharao
Sonntag, 23. November 2008, 12:17
They are rubber sponge, too, but a harder kind so screws can be used to mout the Pump on the "Sandwich"
chaltharr
Sonntag, 23. November 2008, 12:55
Thank you very much for the info. I will have to run to the stores tomorrow and see what i can find.
smoothy
Donnerstag, 27. November 2008, 23:39
how much do these raise the pump up (mm)??
JoFreak
Donnerstag, 27. November 2008, 23:43
about 34mm, if you take 2 layers of the black rubber sponge und 1 layer of the orange rubber sponge in the middle.
smoothy
Donnerstag, 27. November 2008, 23:44
thanks
