• 02.10.2026, 12:30
smoothy
aquatube LEDs
Sonntag, 30. November 2008, 00:45
do the LEDs for the aquatube come with a switch so they can be turned off, say at night when my machine is downloading updates etc?
thanks in advance
Re: aquatube LEDs
Sonntag, 30. November 2008, 01:41
No, just a normal 4-pin plug for the PSU.
smoothy
Re: aquatube LEDs
Sonntag, 30. November 2008, 12:22
is it possible to add an on/off switch to a molex connection?
PsiQ
Re: aquatube LEDs
Sonntag, 7. Dezember 2008, 22:25
Of course.
Its a plain&simpel [+] and [-] connector,
you only have to cut one wire (normally the + one gets switched), put an on/off switch in and you're done.
Turning the switch off means the same thing as pulling the plug.
